If you have enabled driving screen chat in the options menu for offline mode then you can use several commands to help control your race while actually racing at the same time. These commands can be used with the offline chat options enabled method for watching replays as well.
To find what commands can be used go to your root NR2003 directory and locate the server.txt. In here you will find several commands. The most useful one while racing offline or using in replay mode would be these:
An example of setting up these commands as hotkeys to press when racing in offline mode:
!yellow - Used to throw a yellow flag during race sessions. You may not issue this command during the pace lap, or in the middle of a caution period. You can, however, issue it after receiving the one-to-go signal, thus prolonging a caution.!black - Used to issue a black flag penalty to a user during race sessions. The format of the command is "!black player", where player can either be the "#" symbol along with the player's car number, or the player's name.!clear - Used to clear a player's penalties. The format of the command is "!clear player", where player can either be the "#" symbol along with the player's car number, or the player's name. This command is and only valid when the player has a black flag penalty pending, or is currently serving a black flag penalty.!lap+ - Used to give a lap back to a player during a race. The format of the command is "!lap+ player", where player can either be the "#" symbol along with the player's car number, or the player's name.!lap- - Used to take a lap away from a player during a race. The format of the command is "!lap- player", where player can either be the "#" symbol along with the player's car number, or the player's name.An example of setting up these commands as hotkeys to press when racing in offline mode:
