Yeah system32 is where command prompt is located, some reason your pc isn't running it correctly. My account (a local windows 11 account) is an admin account so I have full run control for any program run
Yeah, it's weird. I moved it to desktop, didn't work. I even went into the sandbox folder and booted sandbox up to see if I needed to run sandbox at least once, and after opening sandbox and closing it again make3do.exe nor the batch file still won't functionCould give it a try, I'm not sure what the issue could be honestly. Whats weird is the "This app can't run on your PC" error is only when an app is being installed and all you are doing it starting the basic windows CMD to run the make3doexe
If sandbox is installed then there shouldn't be any other dependencies.
Do you have another pc to try this on? Process of elimination is how I always end up figuring out issues I've had. Also is your windows 10 a full version? For example home/professional? I know there is a windows 10/11 version called S Mode where it blocks any programs that aren't approved by windows, but I doubt that is it if you were able to install Sandbox.
Also when you run the bat can you show me a screenshot of it in the directory, then a screenshot of the error, just want to see if there is some file structure that looks incorrect
For starters, yes I am double clicking, and second, I have commandeered a spare gaming laptop (one of like 5 laptops in my houseAlso when you run the bat file are you double clicking it? You do not want to right click and choose 'run as admin'. Just double clicking to run is needed.
Unfortunately the other PC had the same issueHopefully it works on the other pc, if it does then we know its some sort of config issue on the current one
I had a custom built win 10 pc earlier this year that was like 5+ years old and make3do always worked. I then built a new pc in early 2023 with Win 11 and no issues either. All I did was have my sandbox installed and run the bat files I made in the same directory with the rts.dll and make3do.exe and everything ran as before. No idea why its not working on yours.
