Project wildfire mod utility tips and tricks
First off is sounds yes you can change the sounds of the car here's a little tip you can change the spotter also just add the spotter that you want in the spec folder
You can use this to just change the spotter only just use the default sound just add the spotter that you want to the spec folder. tomorrow I will post more on the track packs
Part 2 trackpacks
These folders use their own shared folder
that you can edited this is how I done the redline tracks to give them the night sky.
if the track needs the updated shared folder then you will have to use it .
And yes you can put 128. Tracks in each folder.this is one of the reason that I use this for series that way you only have the tracks that you need .
One more thing Is the backup and restore this can delete the tracks and sound packs that you installed so don't use this I use zip folders to back them up
Be sure and read the readme text that comes with the project wildfire mod utility..
I hope these help if you need help just ask one more thing the car part I haven't tried yet but soon as I do I will post it.
