Tip Install NR2003 Multiple Times
A quick tip you can learn to improve or setup NR2003 or related tool/program
If you are using the No CD patch version of NR2003 you do not have to manually install NR2003 in the traditional CD method. Instead simply copy/paste your entire NR2003 folder directory and then rename it. You will then have an instance of NR2003 where you can change it to have different mods, tracks, and car files. Simply make a new shortcut to the new NR2003.exe location for that install whenever you want to install it.
