- Joined
- Jan 28, 2023
- Posts
- 9
- Reaction score
- 1
- Points
- 3
My screen resolution is 2160 x 1440 or 3:2. But if that's the case then I didn't read the file readme properly so...yeah. Let me try that.By default when download ICR the DDI should be active. What screen resolution do you play on? Smaller resolution there is a separate folder for the DDI to make it render in and out at proper distance.
Also make sure to read the readme you may need to disable the enable_CarMegaShader=0 in player.ini
Update: It work just like you say but it's a bit weird how in Player Info it doesn't show the series name but it does in Opponent Manager. Futhermore, I tried using DDI with Side Mirror but it doesn't show after I set enable_CarMegaShader = 0. Any idea why it doesn't works for me but it work in your overview update in 1.1?My screen resolution is 2160 x 1440 or 3:2. But if that's the case then I didn't read the file readme properly so...yeah. Let me try that.
