Download here: https://www.adrd-forums.net/index/resources/draw-call-performance-increase-patch.2048/
With so many new mods and exe patches releasing one aspect that has been neglected are performance increases and CTD mitigation. Even before many of these new exe features started coming out NR2003 was prone to CTD when using a very heavy mod combined with a heavy track. For example Daytona BBMC + FCRD22 mod. It was extremely easy when racing or even easier in replay views to crash NR2003 to desktop. The reason was not due to framerate, in most cases a user's FPS could still be 50-80fps when game CTD's.
The reason the CTD's occurred was due to the game's Draw Call limit being hit. Each separate mesh rendered added to the draw call limit and vertex count. This dll patch simply ups the possible vert and indices. The stock rend_dxg.dll locks one dynamic vertex buffer and one dynamic index buffer and copies the frame into them. The vertex buffer is 8,192 vertices. A replay camera on a high-poly wreck, or a car body over 8,192 vertices in one draw, fails every existing buffer, then a new 8,192-vertex buffer is created and the copy writes past the end. The patched DLL uses 32,768 vertices and 65,535 indices. The same track and car sets that crashed on the stock DLL stayed up with this one, in normal racing views and in replay views.
I noticed immediately raising these limits common replay views that would always CTD now no longer CTD. I would swap in and out from the modified dll vs the original dll values and without fail the original would crash the game while the modified one I could watch extremely performance demanding replay views or giant wrecks racing on the front stretch of Daytona BBMC with no CTD's anymore.
If you know certain mods and tracks + replay views crashed your game try this new dll, you might be surprised the CTD's no longer occur. Included in the download is the new dll, readme, and the source code if you prefer to make the dll edits yourself.
One last note I want to make. With these raised limits this is not a call that we should start making mods even more detailed or disregard poly limits, framerate is not changed with this dll so frame related issues will not help if you disregard poly limit because the dll might reduce some CTDs
Since testing the dll I've been able to view any replay and zoom in with no CTD, just a few screenshot example I couldn't take before without the game crashing (using max settings):
