- Joined
- Sep 11, 2023
- Posts
- 28
- Reaction score
- 11
- Points
- 3
but..... the track folder 3dos show instance?
(for me)
(for me)
they do apear in the bottom but it says (instance)The 3dos should now appear in the sandbox list
169 aaaaand the 3dos are from random tracks my badHow many 3dos are in your shared folder? It really shouldn't have more than like 100-200 3dos in it. If you have say 1000 then the list will only show those. The shared fodler should not be used as a storage or repository for all 3dos essentially. Generally shared folder should only have the default NR2003 3dos the game came with and the revamped reloaded 3dos. Other than that all other 3dos should be in the track folders themselves and only add the 3dos in there you plan to actually add to the track (less than 200).
is there any link for the original shared folder? + R&RThe 3dos in the shared folder are just the ones that come with NR2003 when you installed it. Outside of that any 3dos you add to your track could have come from those or other ones you made or got from other track makers (you have permision to use).
nope, the 3do and its mip should just be in the main directory, not the the trackmat folder. Trackmat is just for surface textures on the track
Is the 3do in the your track folder unique and not in the shared folder as well?
